[VAND] Produse Ground Zero (membrii forumului beneficiaza de preturi speciale)
  • [VAND] Produse Ground Zero (membrii forumului beneficiaza de preturi speciale)
    Vand Produse Ground Zero (difuzoare, amplificatoare, subwoofere etc.).
    Produsele sunt noi, nefolosite, vin in amabalajul original, cu accesoriile oferite de producator.
    Pachetul Ground Zero Bass Pack 12” contine: (Poza 1)
    Amplificator GZTA 2.150 MK2
    2 x 75 WRMS @ 4 Ohm (14,4 V, 1% THD)
    2 x 115 WRMS @ 2 Ohm (14,4 V, 1% THD)
    2 x 135 WRMS @ 2 Ohm (14,4 V, 10% THD)
    300 watt max
    stabil in 2 ohmi
    lowpass/highpass reglabil 50 - 250 Hz
    bass boost
    Pret: 317 RON
    Subwoofer GZTB 30 MK2
    Incinta Bass Reflex, diametru 30 cm (12 inch)
    Putere: 400 WRMS
    SPL : 86.7 db
    X-max : 14 mm
    FS : 22.5
    Impedanta : 4 ohm
    Volum: 40 litri
    Grila de protectie
    Pret: 473 RON
    Kit cabluri instalare amplificator GZPK 10 mm2
    6 metri cablu curent rosu (+)de10mm²
    1 metru cablu curent ablastru(-) de 10mm²
    5 metri cablu RCA 5 triplu ecranat cu fir de remote
    5 metri cablu difuzoare 2 x 2,5mm²
    Siguranta AGU 60 amperi
    Alte accesorii/conectori
    Pret: 97 RON
    Pret Total: 887 RON
    Pret promotional pachet Ground Zero Bass Pack 12” Pret: 799 RON ( - 11% )
    Pachetul Ground Super Zero Bass Pack 12” contine: (Poza 2)
    Amplificator GZTA 2.250 MK2
    2 x 165 WRMS @ 4 Ohm (14,4 V, 1% THD)
    2 x 260 WRMS @ 2 Ohm (14,4 V, 1% THD)
    2 x 300 WRMS @ 2 Ohm (14,4 V, 10% THD)
    600 watt max
    stabil in 2 ohmi
    bass boost
    telecomanda bass cu fir
    Pret: 485 RON
    Subwoofer GZRB 12BT
    Putere: 500 WRMS
    SPL : 91.4 db
    X-max : 18 mm
    FS : 30
    Impedanta : 4 ohm
    Volum: 42 litri
    Grila de protectie
    Pret: 591 RON
    Kit cabluri instalare amplificator GZPK 20 mm2
    6 metri cablu curent rosu (+)de 20 mm²
    1 metru cablu curent ablastru(-) de 20 mm²
    Pret: 146 RON
    Pret Total: 1222 RON
    Pret promotional Ground Zero Super Bass Pack 12” Pret: 1099 RON ( - 11% )
    Kit cabluri instalare aplificator GZPK 50 mm2
    6 metri cablu curent rosu (+)de 50 mm²
    1 metru cablu curent ablastru(-) de 50 mm²
    Siguranta ANL 300 amperi
    Pret: 255 RON
    De asemenea, se mai pun in vanzare materiale de insonorizat de la STANDARTPLAST:
    - Vibroplast M1
    - Bimast Standart
    - Bimast Super
    - Bimast Bomb
    - Bureti cu celule inchise (nu retin apa)
    Liniste si pace ...
    Vodafone: 0721.433.295
    Anunt valabil in continuare!
    Liniste si pace ...
      Se pot aduce produse Ground Zero si pe comanda .
      Liniste si pace ...
        Bimast Standart – 210 Lei / pachet
        Material de ultima generatie, format din trei straturi:
        cauciuc sintetic, bitum si material sintetic.
        Se lipeste usor, fara a fi nevoie de aer cald. Grosime
        3mm. Greutate 4,2Kg/mp. Se foloseste la portiere,
        podea, plafon.
        Pachetul contine 10 foi de 40 x 35 cm ( 1.35 mp² )
        Vibroplast M1 – 200 Lei / pachet
        Material cu foita metalica pentru folosire in automobile
        in scopul reducerii vibratiilor. Usor de aplicat, nu
        necesita adeziv.
        Se lipeste usor, fara a fi nevoie de aer cald. Poate fi
        folosit cu succes in cele mai greu accesibile lacasuri.
        Frecventa proprie de rezonanta extrem de scazuta.
        Grosime 2mm. Greutate 2,1Kg/mp. Se foloseste la
        portiere, podea, plafon.
        Bimast Super – 240 Lei / pachet
        cauciuc sintetic, bitum si foita metalica.
        4mm. Greutate 5,8Kg/mp. Se foloseste la portiere,
        podea, plafon.
        Bimast Bomb – 310 Lei / pachet
        4mm. Greutate 6Kg/mp. Se foloseste la portiere,
        podea, plafon.
        Pentru cantitati mai mari, se acorda reduceri substantiale.
        Up!
        Liniste si pace ...
          Valabil!
          Liniste si pace ...
            pune niste coaxiale si compo si preturi te rog
            sigpic........restul e NoSpeedLimit
              Salut!
              Te-ar interesa ceva anume?
              Am foarte multe compo si coaxiale, pe 13, pe 16, depinde si ce anume cauti.
              Tot ce tine de Ground Zero gasesti aici.
              Fii un pic mai explicit si te ajut cu orice informatie doresti.
              Liniste si pace ...
                GZTF 13T sau GZTF 16T
                as vreau si eu un pret pe 4 bucati din fiecare model...
                si ca parerea ai despre aceste modele?
                  Gztc 165t Si Gztc 130t.daca Aduci Si Folie Dynamat Pune Pretul La O Rola
                    @SoNyKeL: GZTF 13T - 2 seturi - 250 Lei
                    GZTF 16T - 2 seturi - 278 Lei
                    @gigi-kent: GZTC 165T - 265 Lei
                    GZTC 130T - 235 Lei
                    Nu am produse de la Dynamat, numai produse de insonorizat de la Stanadartplast.
                    Liniste si pace ...
                      Important!
                      Pentru membrii forumului se acorda reduceri intre 5% si 10%.
                      Daca o comanda nu depaseste suma totala de 500 Lei, reducerea este de 5% din pretul intreg; daca se depaseste suma de 500 Lei, reducerea este de 10% din pretul intreg.
                      Pentru comenzi mai substantiale, nu ezitati sa sunati.
                      Va multumesc!
                      Liniste si pace ...
                        daca ai vazut toate produsele zi-mi si mie te rog cele mai ieftine difuri de 13 cu urm. caracteristici: suspensie membrana din cauciuc, frecventa de la 35Hz si putere cat pentru un cd player normal .
                        multumesc.
                          multumesc.
                          Intervin eu cu niste completari / lamuriri:
                          - suspensie membrana din cauciuc au majoritatea de la GZ.
                          - povesti din astea cu raspuns in frecventa de la 35 hz nu prea o sa intalnesti la GZ. Practic un difuzor de 13 cm sau 16 cm raspunde in frecventa si mai jos de 50-60 hz, dar au o atenuare foarte mare. Deci, difuzorul se misca, si atat, nu obtii bass.
                          Daca ai logan, si vrei ceva bass in usi, iti recomand sa iei 2 inele adaptoare din mdf si sa montezi difuzoare de 16 cm usi. Deasemenea, midbassul unui sistem pe componente ( adica difuzorul care nu are tweeterul in mijloc ) va suna mai bine decat un difuzor coaxial.
                          Eu unul iti recomand Ground Zero Titanium coiaxiale 16T ( GZTF 16T ) sai Ground Zero Titanium sistem 165T ( GZTC 165T ).
                            Multumesc pentru completare dorin_st.
                            Revin cu preturi pentru difuzoare coaxiale si componente, pe 13, respectiv 16 cm.
                            Coaxiale:
                            - GZTF 130MK² - 102 Lei
                            - GZTF 165MK² - 112 Lei
                            - GZTF 13T - 120 Lei
                            - GZTF 16T - 132 Lei
                            Componente:
                            - GZTC 13MK² - 193 Lei
                            - GZTC 16MK² - 214 Lei
                            - GZTC 130T - 227 Lei
                            - GZTC 165T - 256 Lei
                            Liniste si pace ...
                              NOU!
                              Ground Zero GZRF 6900P:
                              Specificatii:
                              * difuzoare coaxiale cu 3 cai
                              * dimensiuni woofer: 15 x 23cm (6"x9")
                              * putere RMS: 250W
                              * putere Max: 350W
                              * impedanta: 4 ohmi
                              * suspensie din cauciuc
                              Aceste difuzoare se adreseaza doritorilor de bas. Amplificate corespunzator, acestea pot aduce suplimentul de bas dorit celor ce nu vor sa ocupe locul in portbagaj cu un subwoofer. Sunt foarte usor de montat, iar sunetul este excelent.
                              Liniste si pace ...
