Dupa cum scrie si titlu vand tv digital portabil MSI D310.
Pret 270 Ron.
Caracteristici: Hardware Specification
System Memory SDRAM:8MB, Flash:1MB
Digital TV tumer DVB-T module
LED Power, power charge
Antenna Embedded
Panel Size 4.2 TFT-LCD Display
IO
- AV out jack x 1
- Headphone jack x 1
- DC-in Jack x 1
- Speaker x 1
- External Antenna In Jack x 1
- SD/MMC slot x 1
Buttons - Power/Hold Switch x 1
- Volume key x 1 set (up/down/mute)
- Navigation Key x 1 set (5-way)
- hot key x 1
- Menu key x 1
- Exit key x 1
Battery Type Lithium Polymar 2300mAH/3.7V
Lithium-ion rechargeable/not removable battery (2300mAh, 3.7V)
Battery Life - Watch DTV 3 hours
- Video Playback 4 hours
- Audio Playback 5 hours
Dimensions 129(H) x 82(W) x 15.6(D) mm
Weight 180gm with battery
Accessory Remote Control x 1, Earphone x 1, AV Cable x 1, Power Adaptor x 1, External Antenna x 1, Antenna Adaptor x 1, Handy Bag x 1, Hand Strip x 1, Users Manual x 1
Regulations CE, CB, UL, BSMI, TUV, C-Tick
Software Specification
OS : Embedded (Firmware could be upgraded by User)
Watch TV (DVB-T) programs support digital teletext, EPG, auto scan, manual scan, change channel, channel search, system setting, video out
Video format : MPEG-4(AVI)
Audio format : MP3
Photo format : JPEG (up to 1024 x 768)
Language English, Germany, Spanish, Italian, French, Traditional Chinese, etc.
Channel Scan Autoscan / Manual scan
Display TV Standard : NTSC/PAL
Display: TV/LCD
Pret 270 Ron.
Antenna Embedded
IO
- AV out jack x 1
- DC-in Jack x 1
- Speaker x 1
- SD/MMC slot x 1
- hot key x 1
- Menu key x 1
- Exit key x 1
Audio format : MP3
Display: TV/LCD
