Dvd jvc kd avx2 exad ....arata si functioneaza bine ,pret 450 lei putin negociabil.
Vand DVD JVC kd avx2 exad
Specifications
AV Systems
Monitor KD-AVX2
Screen Size 3.5 Inch Wide
Screen Resolution 320 x 3 x 234
Color System NTSC
LCD Type TFT Active Matrix LCD
CD Player KD-AVX2
MP3/WMA Compatible with ID3 Tag/WMA Tag Yes
WAV Compatible with WAV Tag Yes
CD-R/RW Compatible Yes
CD Text Yes
Random/Repeat Play Yes
Disc Name Registration Yes
Direct Track Access Yes (with remote control)
DVD Player KD-AVX2
DVD-R/-RW, +R/+RW Compatible Yes
Video DAC 12-bit/108MHz DAC
Video Format NTSC
GIGA MP3 MULTI Yes
DivX(R) Compatible No
DTS/Dolby Digital/MPEG Audio Yes
Dual-Zone Function Yes
Video CD Playback Yes
Shock Proof Memory Yes
Direct Chapter Access Yes (with remote control)
Pause/Step/Slow Yes (with remote control)
Zoom Yes (with remote control)
Frequency Response 16 - 22,000Hz (DVD fs=48kHz), 16 - 88,000Hz (DVD fs=192kHz), 16 - 20,000Hz (CD)
Dynamic Range 93dB (fs=48kHz)
Channel Separation 85dB (at 1kHz, fs=48kHz)
Signal-to-Noise Ratio 95dB (fs=48kHz)
Wow & Flutter Less than measurable limit
CD Changer Control KD-AVX2
MP3 Control Yes (with CH-X1500)
CD Text Yes (with CH-X1500)
iPod/iPhone Control KD-AVX2
Play / Pause / Skip / Search Yes
Text Yes
SDHC/SD [6] KD-AVX2
SD Slot Yes
SD Playback Yes
Radio Tuner KD-AVX2
SIRIUS Ready Yes
Tuner Type
HS-IV Yes
Preset Stations 18 FM, 6 AM
SSM (for FM) Yes
Station Name Registration Yes
AFNS/PNC Yes
Seek (Up/Down) Yes
Stereo/Mono Switch (for FM) Yes
European Switchable Tuner Yes
FM
Frequency Range 87.5 - 108.0MHz
Usable Sensitivity 11.3dBf (1.0uV/75 ohms)
50dB Quieting Sensitivity 16.3dBf (1.8uV/75 ohms)
AM
Frequency Range 522 - 1,710kHz
Sensitivity 20uV
Amplifier KD-AVX2
Maximum Power Output 200W (50W x 4)
Continuous Power Output (RMS) 4CH: 20 watts per channel into 4 ohms, 40Hz - 20kHz, at no more than 1.0% total harmonic distortion + N
MOS-FET Amplifier Yes
Audio DAC 96kHz/24-bit DAC
Source-Specific Volume Control Yes
Volume Attenuator Yes
Balance/Fader Control Yes
Equalizer
7-Band iEQ Yes
Headphone Surround Yes
Max. Amp Gain Switcher Yes
Amp Defeat Switch Yes
Adjustable Line Input Yes (Gold-plated)
Line Output Terminals (pair) 2 Pairs (Gold-plated)
Second Audio Output Terminals Yes (Gold-plated)
Subwoofer Output with Level/Frequency Control Yes (Gold-plated)
Composite Video Output Yes (Gold-plated)
Frequency Response 40 - 20,000Hz
Load Impedance 4 ohms (4 - 8 ohms allowable)
Pre-output level/impedance 2.5V/1k ohms
Video Output Level/Impedance 1.0Vp-p/75 ohms
Video Input Level/Impedance 1.0Vp-p/75 ohms
Audio Input Level/Impedance 1.5Vrms/20k ohms
General KD-AVX2
Face Type
Motorized Slide-Out Face Yes
Detachable Face Panel with Carrying Case Yes
Wireless Remote Control
Multi-Function Wireless Remote Control Yes
COMPU PLAY Yes
Tel. Muting Yes
Power-Off Mode Eject Yes
Dimensions (W x H x D)
Installation Size 182 x 52 x 160mm
Panel Size 188 x 58 x 12mm
Detachable Face Plate Size 169 x 58 x 20mm
Weight 1.9 kg
Features
Power Output:20W x 4 (RMS) 50W x 4 Max.
MOS-FET Power Amp
Built-in 3.5-Inch Wide Monitor
GIGA MP3 Multi
7-Band iEQ
Ready for iPod* In Conjunction with KS-PD100
SAT Radio Ready
MP3/WMA DVD-Audio WAV CD/CD-R/CD-RW Compatible with ID3/WMA Tag
JPEG Playback
DVD-R/-RW,+R/+RW,VCD Multi-Border DVD Compatible
5.1 Channel DTS/Dolby Digital/Dolby Pro Logic II/ MPEG Audio
Time Alignment (5.1ch)
Gold-Plated Line Output Terminals (2 Pairs)
Gold-Plated Center Channel Output Terminal
Gold-Plated Video Output Terminals
Second Gold-Plated Audio Output Terminals
Gold-Plated Subwoofer Output Terminals with Level/Frequency Control
Gold-Plated AV Input Terminals
Motorized Slide-Out Faceplate
Dual-Zone Function with Headphone Surround
WallPaper Setting
Shock Proof Memory
Fa mi o oferta..........
