Originally posted by evali_daniel
View Post
[Vand] Consumabile si piese noi
Anunt valabil in continuare:
- maneta stergatoare cu buton Cb la------------- 65 ron/buc
- bloc lumini cu proiector model Valeo------------ 130 ron
- bucsi bascule de origine ------------------------ 20 ron/buc
- bujii Equiem------------------------------------ 55 ron/set
- termostat (producator) LG diesel--------------- 115 ron
- cap bara Lemforder ----------------------------- 90 ron/buc
- bieleta directie Lemforder------------------------ 90 ron/buc
- cap bara de origine------------------------------ 90 ron/buc
- bielete directie de origine------------------------ 80 ron/buc
- termostat benzina------------------------------- 35 ron
- pivoti (LEMFORDER)------------------------------ 35 ron
- bascula de origine------------------------------- 110 ron
- set saboti (ATE)-------------------------------- 135 ron
- nuca schimbator Prestige normala------ ---------- 35 ron
- bucsi bara stabilizatore mijloc -------------------- 20 ron/buc
- bielete antiruliu de origine ------------------------ 25 ron/buc
- rulmenti roata FAG fara ABS ---------------------- 95 ron/buc
- rulmenti de spate originali la ---------------------- 75 ron/buc.
- rulmenti fata originali pentru model fara ABS la ----- 75 ron
- rulment roata cu ABS model 2007 ---------------- 140 ron
- filtru ulei original Purflux benzina ------------------- 15 ron
- filtru ulei original Motorina ------------------------- 20 ron
- filtru aer benzina si motorina ----------------------- 25 ron
- filtru aer 16 valve --------------------------------- 30 ron
- filtru motorina EURO 3 ---------------------------- 115 ron
- filtru motorina EURO 4 ---------------------------- 125 ron
- filtru polen Valeo ---------------------------------- 25 ron
- oglinzi Prestige electrice ---------------------------270 ron/set
- proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
- buton reglaj oglinzi electrice ------------------------35 ron
- buton deschidere usa -------------------------------10 ron
- amortizoare Monroe fata ----------------------------120 ro/buc
- amortizoare Monroe spate --------------------------105 ron/buc
- amortizoare Bilstein B4 fata -------------------------145 ron/buc
- amortizoare Bilstein B4 spate ------------------------125 ron/buc
- flanse amortizor originale -----------------------------35 ron/buc
- rulmenti amortizor SNR -------------------------------25 ron/buc
- bieleta antirasturnare --------------------------------75 ron
- carcasa cheie cu telecomanda ----------------------- 50 ron
- discuri frana VAN Brembo --------------------------- 135 ron/buc
- placute frana VAN Ferodo SL ------------------------125 ron/set
- discuri frana 259 pline Ferodo ------------------------175 ron/set
- discuri frana 259 ventilate Ferodo --------------------190 ron/set
- placute frana TRW ----------------------------------- 60 ron/set
- placute frana Ferodo FQT ----------------------------125 ron/set
- cablu ambreiaj MPI-DCI -------------------------------45 ron
- cablu acceleratie MPI -------------------------------- 35 ron
- sonda servodirectie -----------------------------------50 ron
- sonda mers inapoi -------------------------------------35 ron
- plafoniera 3 becuri ------------------------------------35 ron
- plafoniera 1 bec ---------------------------------------30 ron
- contactor lumina pedala frana ------------------------- 20 ron
- spirala airbag volan ------------------------------------ 80 ron
- kit distributie MPI -------------------------------------185 ron
- pompa apa de origine MPI -----------------------------220 ron
- pompa apa HEPU pt benzina ---------------------------175 ron
- kit distributie DCI ------------------------------------- 320 ron
- pompa apa DCI ----------------------------------------215 ron
- kit ambreiaj EXEDY 1.4 MPI ---------------------------- 285 ron/set
- kit ambreiaj EXEDY 1.6 MPI -----------------------------385 ron/set
- curele accesorii ---------------------------------------- 55 ron
- kit accesorii MPI model cu AC de origine -----------------235 ron
- kit accesorii DCI model cu AC de origine -----------------255 ron
- spray luciu anvelope ------------------------------------24 ron
- autocolante stalpi Prestige ------------------------------35 ron/set
- aeratoare Prestige argintii -------------------------------65 ron/set
- ulei motor, ELF, CASTROL, MOBIL-------------------------Intrebati
si multe altele...se pot aduce si piese pentru masini straine
evali_daniel este id-ul meu
si pozele .
