100 % functional ; se livreaza impreuna cu manualul de utilizare , etui , rama de fixare in bord
PERMITE SETAREA DISPLAY-ULUI IN 4096 NUANTE !
Car-Kit Bluetooth incorporat
pozele sint reale !
Radio CD/MP3 player cu modul Bluetooth , intrare USB si AUX-in
Redare : MP3 , WMA
Intrare USB
Display VarioColour tip DOT (1 linie)
Tuner cu RDS , EON , TA , TP si memorie pentru 25 de posturi
Putere : 4 x 50W
Intrare Aux pe panoul frontal
2 preout-uri (2V)
Panou frontal detasabil
Egalizator pe 3 benzi semi-parametric
Reglari presetate : Classic, Pop, Rock
Iluminare taste : rosu
Blaupunkt Toronto 400 BT car radio key features
Attractive radio CD receiver with built-in Bluetooth adaptor for making safe, legal hands-free phone calls.
Black removable front panel, large variable-colour (4,096 shades) display and red button illumination.
Powerful 4 x 50W amplifier with X-BASS loudness and comprehensive tone control.
Stereo preamp outputs give option to add external amplifier.
Front panel USB socket for memory stick file stores, plus aux-input jack socket to connect MP3 player.
Radio tuner features:
LW / MW / FM waveband coverage. 30 stations can be preset
RDS-AF (alternate frequency) feature inaudibly retunes the receiver to the best available signal for the station that is currently set
Travelstore automatically stores the six most powerful radio stations transmitting locally in the FM memory bank
TA (traffic announcement) will switch station for the duration of a traffic report. The original station is restored at the end of the report. Tone, balance and volume of traffic announcements can be independently set
PTY-EON (programme type) information displays and allows selection of similar types of programme (news, pop, classics, sport etc.)
Preset scan will play all receivable stations for a period (can be adjusted between 5 and 30 seconds)
Bluetooth features:
Integrated Bluetooth module with built-in microphone allows making & answering / rejecting phone calls while your mobile phone remains in your pocket
Up to five different mobiles can be registered to head unit
Phone call audio is initially played through radio's speakers, but can be re-directed to phone if required
Bluetooth interface also supports audio streaming
CD features:
Will play standard audio CDs and CD-R&R/W discs
CD deck incorporates shock-proof memory to reduce skipping
Fast searching, random play, pause, track scan and track repeat functions
Display can be set to show track number & clock time or track number & playing time
MP3 / WMA features:
MP3 / WMA decoder will support variable bit rates between 32 kbps and 320 kbps
Both directory and file names can be displayed. Unit will also display ID-3 tag (version 1) information
Display can be configured to always scroll directory / file / artist / track / album name once, every time a track is selected
Fast searching, random play, track scan and track repeat functions
Amplifier features:
4 x 50W max power amplifier (4 x 26W RMS). Separate adjustments for treble, bass, fader and balance
Source-specific sound adjustment. Bass & treble settings can be different for each sound input source (radio / CD / CD changer / auxiliary input)
Equaliser is preset with settings suited to either POP, ROCK, CLASSIC etc. music styles, or adjust manually
X-BASS loudness sound enhancement for low level listening. Programmable in four stages for a full sound at lower volumes
Power-on and mute volume can be independently set
Two stereo (2.0V) RCA preamp outputs for connecting external amplifiers (requires accessory cable)
Other features:
Front panel mounted stereo jack socket for direct connection of iPod, MP3 player etc.
USB connection allows MP3 players, memory sticks or compatible hard drives (max. current load 800mA) to be connected to radio for playback of MP3 or WMA files. Media must be specified as a mass storage device and formatted to FAT16 or FAT32 standard. (Very large file stores may result in slow file searches)
Display illumination colour can be set to any one of 4,096 different shades
Auxiliary input socket available at rear of radio (requires accessory cable)
Blaupunkt compatible infra-red remote controls can be added as an optional accessory. Unit can be linked to many makes of factory-fitted remote controls with an additional adaptor
Demo mode
Mute facility can be manually selected, or automatically activated by hands free phone call. Mute volume level is adjustable
Timer allows one hour of use with ignition switched off, to protect vehicle's battery
Clock display (12/24hour) can be selected
Red control button illumination
pret : 440 lei
pozele sint reale !
Redare : MP3 , WMA
Intrare USB
Putere : 4 x 50W
2 preout-uri (2V)
Bluetooth features:
CD features:
MP3 / WMA features:
Amplifier features:
Other features:
Demo mode
pret : 440 lei
