se vinde/schimba un subwoofer 10 inchi JL 10W3V3D4 Audio MAde in USA, foarte rapid, in incinta bass reflex, neabuzat (nu am avut eu cu ce sa l abuzez) incercat de userul alpine_clarion, se da doar ca aceasta cutie nu am ce sa fac cu ea ,schimb doar cu subwoofere 12-13 inchi (JL, HELIX,DD), in cazul vanzarii cumparatorul achita toate taxele de transport
specificatiile o sa le atasez un al doilea post
pret 550 ron usor negociabil, se trimite prin ce doreste cumparatorul
tel 0745086800 sau pm pe site
specificatii si dimensiuni incinta bass reflex Continuous Power Handling (RMS) 500 W
Recommended RMS Amplifier Power 150 - 500 W
Nominal Impedance (Znom) 4 Ω
Nominal Diameter 10.0 in / 250 mm
Overall Diameter (A) 10.5 in / 267 mm
Mounting Hole Diameter (B) 9.0625 in / 230 mm
Bolt Hole Circle (C) 9.7 in / 246.5 mm
Magnet Diameter (D) 5.25 in / 133 mm
Mounting Depth (E) 5.93 in / 151 mm
Driver Displacement 0.049 cu ft / 1.39 L
Net Weight 12.25 lb / 5.56 kg
Free Air Resonance (Fs) 31.49 Hz
Electrical “Q” (Qes) 0.523
Mechanical “Q” (Qms) 7.017
Total Speaker “Q” (Qts) 0.485
Equivalent Compliance (Vas) 1.138 cu ft / 32.23 liters
One-Way Linear Excursion (Xmax)* 0.550 in / 14.0 mm
Reference Efficiency (no) 0.19%
Efficiency (1 W / 1 m)** 84.87 dB SPL
Effective Piston Area (Sd) 53.475 sq in / 0.0345 sq m
DC Resistance (Re) 3.567 Ω
Wall Thickness 0.75 in / 19 mm
Front Baffle Thickness 0.75 in / 19 mm
Volume (net int.) 1.125 cu ft / 31.9 L
External Width (W) 23 in / 584 mm
External Height (H) 12 in / 305 mm
External Depth (D) 13 in / 330 mm
Internal Slot Port Width (SW) 1.25 in / 32 mm
Internal Slot Port Height (SH) 10.5 in / 267 mm
Internal Slot Port Depth (SD) 28.625 in / 727 mm
Port Extension Length (EL) 15 in / 381 mm
Tune to 31.8 Hz
F3 31.7 Hz
am citit regulamentul si sunt 100% pro el
Tune to 31.8 Hz
F3 31.7 Hz
