Vand urmatoarele scule:
vand amplif pioneer gm 3200t
amplificator 2 canale
putere Max: 2 x 120W sau 1 x 300W (4 Ohm)
filtru LPF: 80 Hz, -12 dB/Oct
nivel semnal intrare: 400 mV - 6.5 V
distorsiuni < 0.008 %
raport semnal/zgomot (S/N ratio) > 100dB
dimensiuni: 300 x 61 x 195 mm
greutate: 2.7 kg
360 lei, am factura, cutia si garantia.
il vand pentr ca fac upgrade.
un set difuzoare ovala pioneer TS-A6911. La beloud. Ro sunt 250 lei, eu le dau cu 140 lei. Sunt in garantie si putin folosite.
difuzoare pe 3 cai
dimensiune 6 x 9"
putere: 80W RMS (330W max)
SPL: 93 dB
impedanta 4 ohmi
raspuns in frecventa: 25 - 30.000 HzHz
diametru tweeter midrange: 57,0 mm
diametru tweeter: 18,0 mm
un set difuzoare pentru usi pioneer TS-G1349 la 70 lei.
Difuzoare coaxiale 2 cai
diametru: 13 cm
putere 25W RMS (130W max)
impedanta: 4 Ohm
raspuns in frecventa 50-25000 Hz
sensibilitate (1W/1m): 89dB
membrana din polipropilena
Cd player cu mp3 pioneer DEH p 4800MP la 450 lei
Radio CD si MP3 player auto
amplificare interna 4x50W, MOSFET
procesare sunet: HPF, LPF, EEQ Plus, FIE (Front Image Enhancer), SFEQ (Sound Focus Equaliser)
panou frontal detasabil
buton volum rotativ
Compatibil CD-R,CD-RW, MP3, WMA, WAV, CD-Text
tuner compatibil RDS
iesiri preout RCA: 2 (F, R sau S/W)
intrare AUX-In
IP-Bus
toate au cutie, carti, accesorii si garantie.
subwoofer Pioneer TS SW841D
Specificatii
Marime - 8" sau 20 cm
Putere muzicala maxima - 500 Watts
Putere nominala RMS - 120 Watts
Frecventa de raspuns - 30 ~ 1,500Hz
Senzitivitate - 85dB
Impedanta - 4 ohm
Inchidere recomandata - 0.15 ~ 0.5 Cubic Feet
Dimensiuni - 8-7/8" x 3"
Adancimea de montaj - 63.5 mm
Descriere
Woofer Cone Material Composite IMPP using Interlaced Carbon Fiber and Ultra Long Glass Fiber
Woofer Cone Design Double Cone with Air Suspension Control System
Surround 3-Layer Fiber Woven Radial Surround with M-shape Cross-section
Voice Coil 4 Layer, Long Voice Coil
Voice Coil Wire Copper
Voice Coil Bobbin Glass Cloth
Damper (Spider) None (Air Suspension Control System)
Top Plate T-Pole Yoke
Projected Pole Yoke with Vented Pole
Magnet Construction Strontium
Basket Design Cast Aluminum Basket with Fin-Shaped Design
Gasket Rubber
Wire Terminals Spring Compression
Se vinde si cu incinta din poza la 500 lei.
greutate: 2.7 kg
difuzoare pe 3 cai
dimensiune 6 x 9"
SPL: 93 dB
impedanta 4 ohmi
diametru: 13 cm
impedanta: 4 Ohm
buton volum rotativ
intrare AUX-In
IP-Bus
Specificatii
Impedanta - 4 ohm
Descriere
Gasket Rubber
