Greetings from Moscow
Washing of throttle knot.
Run 73500км. Has disassembled the air filter case. Has pulled out an air filter. Has removed the case.
Has for this purpose turned off in front of 2 sprockets and behind two. It is possible to take advantage of a key on 10.
To separate the case from an air shutter it is necessary to pull the case upwards and to turn a little in the parties, on hour / and against an arrow. Having separated the case from a bore where air is sucked in we push a hand downwards on the right under the case and having groped a tube, we separate it from a filter casing. For this purpose to remove knot of a throttle we unhook the pull-rod going from a cable of gas.
Then having unhooked two gauges, on the right and behind throttle knot, we turn off a bolt under TORX30, we take out a half ring which holds the case of a throttle, a bolt to unscrew up to the end not necessarily.
If to look narrowly, it is possible to understand that the collector does not shine. On it a dirt and oil layer. In the course of works it can be wiped a rag moistened in a cleaner. Shine will appear. P.S. First two photos are made already in the course of assembly, clean hands. Therefore you can see as in a throttle all shines!
Finger has spent on a wall that it was visible what layer of a fat dirt inside better. Itself шторка it is made of black plastic and consequently on a photo the dirt load condition is not so visible. It is necessary to notice, what not so that there and all is strongly started. The dirt is, but is not fatal. Cleaned a carburettor Cleaner. In shop it is possible to buy any, at me was such.
The interior has aluminium a ring, a contact place шторки and cases. It was not clear colour, soot and a dirt. Presoaked a cleaner and some minutes waited. Repeated 2 or 3 times. Wiped a pure rag. And here result. Walls shine
Assembled all upside-down. Problems with motor start was not. Glitches it is not revealed. It was started from the first. Worked exactly. Has swept round area. Roofing felts it seemed, roofing felts in the truth, a pedal it began to be pressed is easier... The Resume. Time has occupied about an hour. Did one. While photographed also hands wiped and washed the air filter case. It is necessary to notice that in our throttle valves there is no so much dirt, how many at competitors.Attached Files- Изображение 023.jpg (840.1 KB, 233 views)
Has replaced a grid in a fuel tank. It costs on the fuel pump. A new grid - white. An old grid - on a photo. Fuel very bad. It is a lot of dirt. Run 72ооо km.
Greetings, guys.
Again to you huge greetings from Moscow.
Yesterday has changed oil in transmission.
Photo.
1.Oil from transmission.The black. Dirty.
2. New oil in transmission. Castrol Масло трансмиссионное TAF-X 75W90 GL-4/5
Run 72000 km.Attached FilesLast edited by Cubik; 29 October 2008, 18:47.
Result. The stream on glass does not run. It is brushed away by a window wiper of the passenger party.
We alter a screen wiper trapeze
1.We take out clip-on earrings from both parties.
2.The elastic band acts in film, we take out clip-on earrings from both parties
3.We take out a lattice, turning off nuts on 13 it is removed yard keepers
4.Under plastic caps there are nuts on 24 is turned off them, preliminary having removed caps. All drive gear together with a trapeze keeps now only a bolt on a reducer under 10 key.
5.Having turned out it and разъеденив a socket, it is possible to take this device outside
6.Before to take out the lever, the passenger yard keeper, the lock ring is pulled out
7.We take out the lever.
8.The size of a shoulder of 85 mm. To make it has been solved on 5мм by cutting half-and-half and сваривания by welding less
9.Prepares in return sequence, between all трушимися the details, those which understood, has been added lubricants.
10. Result: the top end of a passenger cleaner does not reach to pure the top edge of the driver's party, hardly there is less than centimetre.
Very very nice it is a n excellent ideea.
Your car it's great.Good work!
Hello, Cubik. It's an original idea, i dont' think i've seen it before on a logan, at least not in this shape. Very nice, congratulations
If it is interesting to whom so the tube and a light-emitting diode strip in it looks.
LED the strip is sealed-in in a tube which should be heated, and pasted under a headlight on glue, on a side of a headlight
