dupa o calibrare la instalatia mea de pe logan AC stag200(AC Stag 11.1.0.14 software), mi a aparut urmatoarea eroare. "This system is not supporting this area and the controller has been locked. Please kindly contact to authorized distributor of AC products"
daca v ati lovit de asa, ceva rog ajutor! multumesc anticipat!
da a aparut dupa prima calibrare si nu mai imi da voie sa accesez calculatorul de gpl
am gazit ceva pe un forum de Poland, ,,Regarding to this issue , we find some reasons .
First there is a possibility that operation system (Windows) is installed on PC from example : United State , so system and PC has internal geo-taging codes.
Please to run old one app 10, then re-flash Ecu using this PC ( bought and system localized from Your market) . After that using this same PC download app 11 and try use it again.''
dar nu stiu cum se face...,, re-flash Ecu...''
am gasit ceva asemanator pe un forum in Poland,,Regarding to this issue , we find some reasons .
am inteles bine ca trebuie sa reinstalez versiunea veche de soft 10.4.0.5 si sa fac un re-flash Ecu?...care nu am idee cum se face.
Reason: Automerged Doublepost
Instalatie landi Renzo montata de app 2500 km, dupa mine se comporta ciudat atunci cand revine la relanti (stationar sau sarcina).
In Video-ul de mai jos primele 2 "reveniri" sunt cu masina functionand pe GPL iar urmatoarele 2 cu masina functionand pe benzina (in rest masina merge bine si pe benzina si pe GPL).
Am fost la service-ul unde am montat instalatia, mi-au facut o diagnoza, au zis ca totul este in parametrii si intradevar este ciudata manifestarea.
Urmeaza sa verifice si alte motorizari similaresa vada daca au aceeasi comportament.
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Vreo idee de la ce poate fi ?
Multumesc,
La fel face si la mine.
Logan 1.4, 2008, 180.000 km, GPL de fabrica.
La mine ramane un moment turatia pe la 1000, apoi scade la ralanti.
Injectoare MED schimbate de un an.
Am facut recalibrare, nu s-a rezolvat.
Dar masina merge bine.
Buna,
Ma puteți ajuta cu un soft Landi Omegas,pentru Ecu Multipoint FW 16.00, 616264001, 511415600016 instalat in Germania in 2011 pe un Ford Focus 1.6 Benzina.
Am incercat variante Landi omegas insa imi da eroarea C03 sau ecu not responding,Com la cablu a fost pus 1 sau 2,contactul pus/motorul pornit, am inversat si pini la mufa de conectare,Tx cu Rx.
E posibil, fiind montata in Germania,sa fie firmware Landi Opel sau Vw.
Mulțumesc
Daca nu ai interfata ok pentru Landi, te joci degeaba...
Din ce am vazut pt Opel si VW mai erau softuri personalizate...Idem pt Renault/Logan
Vezi daca gasesti ceva de Ford...ma indoiesc ...
