Very high performance lubricant based upon ELF synthetics technology, designed for
lubricating all Diesel car engines.
APPLICATIONS
All Diesel engines, especially those of recent technology
Even in very severe conditions
Fast driving
All times of year, even the coldest weather
Recommended for all supercharged or naturally aspirated Diesels in cars and light vans.
Suitable for all types of service (urban, or on the highway or motorway) especially in very severe conditions.
For all types of driving, especially at high speed.
Specially designed to meet the demands of the motor manufacturers as regards extended oil-change intervals.
Refer to the maintenance book of your vehicle to know the recommendation of the manufacturer.
PERFORMANCES
International specifications
OEMs approvals
ACEA 2004: A3/B4
API: SM/CF
RENAULT : RN0710, RN0700 : gasoline, turbo gasoline and Diesel without Diesel Particulate filter, 2.2 dCi DPF
CUSTOMER BENEFITS
Best possible performance
Excellent engine cleanliness and
protection
Easier starting in very cold conditions
Longer engine life
Extended oil-change intervals
Excellent engine protection, particularly against wear in the timing system.
Ensures an exceptionally clean engine.
Outstanding thermal stability and oxidation resistance, guaranteeing that the oil will not degrade even in conditions of very severe use.
Immediate lubrication of engine components during cold starts, leading to longer engine life.
Lubricant performance sustained over time for extended oil change intervals.
CHARACTERISTICS
ELF EVOLUTION SXR 5W-40
Method
Units
SAE Grade 5W-40
Density at 15°C
ASTM D1298
kg/m3
854
Viscosity at 40°C
ASTM D445
mm2/s
82.2
Viscosity at 100°C
ASTM 445
mm2/s
13,6
Viscosity Index
ASTM D2270
169
Pour Point
ASTM D97
°C
-39
Flash Point
ASTM D92
°C
226
B.N.
ASTM D2896
mgKOH/g
9
The typical characteristics mentioned represent mean values
This lubricant used in accordance with our recommendations and for the application for which it is intended does not represent a special hazard.
A safety data file conforming to the requirements of current EC legislation is available from your local trade consultant
tavi....fi mai atent....acum ti-am si ingrosat si subliniat...ca sa vezi.
am mai gasit si eu cateva specificatii pe net : asta , asta , http://translate.google.ro/translate...3Dro%26tl%3Den
APPLICATIONS
Fast driving
PERFORMANCES
OEMs approvals
ACEA 2004: A3/B4
API: SM/CF
CUSTOMER BENEFITS
protection
Longer engine life
CHARACTERISTICS
Method
Units
SAE Grade 5W-40
Density at 15°C
ASTM D1298
kg/m3
854
Viscosity at 40°C
ASTM D445
mm2/s
82.2
Viscosity at 100°C
ASTM 445
mm2/s
13,6
Viscosity Index
ASTM D2270
169
Pour Point
ASTM D97
°C
-39
Flash Point
ASTM D92
°C
226
B.N.
ASTM D2896
mgKOH/g
9
intradevar...cu litere de o schioapa..si cu asta eu nu mai comentez nimic.
), te rog nu incurca oalele.
