@mumus O posibila problema: apa in portierele spate(mai ales stanga) atat la Toledo cat si la varul Rapid.
Seat Toledo
la mine nu cred ca e cazul, la megan, si am inteles ca si pe la dacii se infiltra pe la difuzoare, eu pe spate nu am asa ceva.
Si nu ai aflat si motivul ?Originally posted by t0rquemada View Post@mumus O posibila problema: apa in portierele spate(mai ales stanga) atat la Toledo cat si la varul Rapid.Un om inteligent nu va fi niciodata rau. Rautatea se naste din prostie, inferioritate si frustrare.
I have a nearly new (11 month old) SEAT Toledo.
One of the rear doors fills up with water whenever it rains - large amounts of it sloshing around.
Pulling the rubber door seal over the drainage holes (it seems to be covering them) releases the water which literally comes gushing out.
The SEAT dealer, under warranty, have offered to "unblock" the drainage, which I suspect may mean bending the seal a little so that it isn't sitting over the drainage holes.
However, no one seems concerned that this amount of water is running through the inside of the door in the first place (after half an hour of heavy rain, I can get about a pint out of the bottom of the door).
Is it correct that this amount of water should be travelling through the inside of the door? Or should I be pushing to get the window seals replaced so that it isn't getting in there in the first place?
The inside of the doors will always get wet with rain water or washing the car as they are deemed a "wet area" by VAG. Replacing the glass seals won't stop water ingress as they don't create a positive seal, maybe slow it down a little if they are faulty, but not stop water entering.
Possibly the drain holes in the bottom of the door are either partially blocked by wax sealant or the lower door apature seal is out of line pushing it over the actual door seal and covering the drains ? If it's only effecting one door there has to be a reason why as the other doors are fine yes ?Pentru H4B(0,9 TCe) datu' cu părerea (mai ales cand nu ai toate datele) e sport național - Do not feed the trolls.
E clar, usor de rezolvat daca cumva apare apa. La mine momentan e uscat, ieri chiar am prins o ploaie urata rau.
Azi am fost la RAR sa scot cartea masinii. Dip MNotors a platit cei 196 lei.
Reprezentanta dacia plateste oare RAR-ul ?
* Dip Motors BrasovUn om inteligent nu va fi niciodata rau. Rautatea se naste din prostie, inferioritate si frustrare.
Ce avem noi aici
Attached FilesUn om inteligent nu va fi niciodata rau. Rautatea se naste din prostie, inferioritate si frustrare.
