numa televizor olimp H2 sau venus.dar tre sa gasesti lampi pl.scuze de off da nu m-am putut abtine.
Bazar Pitesti
Pret 2mil negociabilOriginally posted by Champion View PostVand monitor SAMSUNG SyncMaster 793df 17inch aproape nou [ATTACH]286243[/ATTACH]
Diagonala :17
Rezolutie optima :1024x768 / 85 Hz
Tip tub : DynaFlat
Dimensiune punct (mm) :0.20
Rata verticala de refresh (Hz) :50-160
Rata orizontala de refresh (KHz):30-70
Rezolutii suportate Maximum 1280x1024 / 65 Hz
Standarde: MPR-II
Display
Semnal intrare: 15-pini d-Sub,Separate H/V
Putere consumata (W): 80
Vand monitor SAMSUNG SyncMaster 793df 17inch aproape nou Atasament 286243
Diagonala :17
Tip tub : DynaFlat
Standarde: MPR-II
Display
- GeForce Gainward 6600GT - 128Mb / AGP - 50 lei
- aparat foto Fuji S5800 + accesorii (filtre, parasolar, inel step-up) - 620 lei
- Hifonics ZEUS POWER BASS PACK (woofer + amplificator + cablaj) - 1800 lei
- Sistem AMD - Procesor AMD Quad-Core 9500, placa baza Gigabyte GA-M56S, 4Gb RAM DDR2, 2 x 500 Gb HDD, GeForce 9800 GT 512 Mb, DVD RW, Card reader, sursa Spire, carcasa RAIDMAX Sagitta 2 Black - 1550 lei
- Monitor LG 22" , gri, DVI + VGA, Rezolutie 1920 x 1080 pixeli - pret 600 lei
- 2 seturi leduri tetiere + 2 neoane albastre + un neon mov = 80 lei
- HDD Seagate, SATA-II, 500GB - 200 lei
- schimb capota cu priza activa si badboy cu model stock + diferenta
uite ca gasestiOriginally posted by alexutzu View Post@hmv...consola aia daca o mai gasesti pe undeva mai jos de 80-100 de lei nu o s gasesti
-aparatori fata+spate logan 60 ron setul (30 ron fata/spate)
-maciulie ph1 20 ron (in stare foarte buna
-actuator 30 ron
-cuie usi ph2 40 ron (4 buc)
-contactor portbagaj 10 ron
-capacel janta aliaj 15 ron
-suport butoane geamuri electrice spate 10 ron
-tunel de sub maneta de viteza ph1 20 ron
-carcase chei supernova/solenza cu buton 35 ron
-lampa torpedou/portbagaj (fara intrerupator) 20 ron
-faruri ph2 450 ron setul
-4 injectoare noi renault 1,9dci (se poate vedea codul de reper in poza) -10 mil
-plafoniera logan noua cu 1 bec 30 ron
-plafoniera logan noua cu 3 becuri 50 ron
-sonda marsarrier LOGAN 60 ron
-contactor pedala frana LOGAN DCI 35 ron
-joistick oglinzi electrice 40 ron
-contactori usa 10 ron
-cablaj proiectoare ph1 (cablaj Y) 45 ron
-suporti proiectoare bara mcv ph1 65 ron
-grila bara mcv ph1 55 ron
-maciulie logan ph2 negra 35 ron
-maciulie logan prestige 50 ron (fara piele)
-maciulie logan prestige 70 ron (din piele)
-comanda ventilatie logan ph1 70 ron
-comanda ventilatie logan ph2 100 ron
-comanda volan audio (duster, black line) 75 ron
-consola centrala gri logan ph1 50 ron
-inele aeratoare negre originale 35 ron/setul
-inele aeratoare albastre –30 ron/setul
-inele aeratoare gri –30 ron/setul
-ornament negru tija deschidere/inchidere panou logan ph2 – 20 ron setul(4 buc)
-buton blocare/deblocare usi ph2 - 20 ron
-buton dezaburire luneta ph2 - 20 ron
-butoane geamuri spate logan (cu suport) - 50 ron/2buc.
-geam oglinda ph1 cu incalzire (st+dr) 25 ron/buc
-bujii incandescente beru logan diesel (originale) 120ron
-bujii logan/dsn/solenza eyquem (1 electrod) 50 ron
-bobina inductie 100 ron
-cablu acceleratie 50 ron
-butoane geamuri solenza/logan spate(cu tot cu suport) 50 ron
-fise bujii beru originale 85 ron
-buton avarie solenza nou (sigilat) 45 ron
-opritor usa logan 50 ron
-oglinzi electrice incalzite ph1 150 ron setul (negociabil)
-oglinzi electrice incalzite noi ph2 350 ron setul (culoarea capacului la alegere)
-carenaje scaun gri deschis ph1 30 ron/setul
-carenaje scaune gri ph2 40 ron/setul
-manere panou ph2 90 ron/setul
-manson schimbator original 40 ron
-clapeta deschidere usa ph2 (gri) - 15 ron bucata
-curea distributie logan MPI de origine (cu rola) 220 ron
-pompa apa logan MPI de origine 240 ron
-diferite componente ale ceasurilor de bord
-manere complete panou ph2 (manere+baghete) 120 ron/setul
-ceasuri bord logan/duster/sandero - 140 ron (cb) (0 km la bord) (se poate adauga si geamul pt. 30 ron)
-ceasuri bord logan prestige - 170 ron (cb) (0 km la bord) (se poate adauga si geamul pt. 30 ron)
-maciulie piele + mason schimbator - 100 ron
-autocolant stalpi - 50 ron setul (4 buc.)
-buton avarie logan - 35 ron
-actuatoar usa logan - 35 ron/buc (120 ron setul 4buc)
-sonda servodirectie logan - 60 ron
-aparatori aripi logan - 65 ron setul (fata+spate)
-cochilie volan ph1 (completa) - 60 ron
SERIGRAFIE DUSTER MPI/DCI - 65 RON (FARA ACE)
SERIGRAFIE ALBA - 65 RON (FARA ACE)
INELE BORD PRESTIGE - 50 RON
INELE BORD LAUREATE - 35 RON
INELE BORD DUSTER - 50 RON
ECRAN NEGATIV - 50 RON
GEAM CEASURI BORD NOU - 40 RON
Vand
-autocolant stalpi imitatie carbon negru sau gri- 55 ron setul (4 buc.)-Montajul 10 ron in Pitesti
-ornamente clapeti interior si exterior imitatie carbon negru sau gri 10 ron/set
-Colez consola climatizare Logan Ph1 -45Ron (inclus materialul imitatie carbon negru sau gri)
-Prelungire bara cauciuc 60Ron
Poze in albumul meu
telefon:0742060266
-difuzor bara spate ph1 80 lei
-fise bujii 80 ron set
-aparatori aripi 60 ron
-maciulie prestige 40 ron
-colant stalpi prestige 50 ron
-maneta stergatoare cu buton cb.70 lei
-senzor temperatura 70 lei.
-aparatiri noroi set 4 bucati plus aeratoare 50 ron set
-etrieri de van 170 lei setul
-triple spate cu leduri 370 ron noi
-grila bara mcv 50 ron
-suporti proiectoare mcv 55 ron setul
-placute de van 110 lei setul.
-eleron luneta 110 ron
-pompa servo 280 ron.
-planetare benzina 800 ron setul.
-bielete directie si capete bara cu burduf. set toate 4. 350 lei.noi.
-placute de origine 90 lei.noi.
-fagure bara ph1 plus deflector 40 lei
-plafoniera cu 3 becuri 35 lei
-etrieri normali noi la 80lei amandoi.
-pompa apa 170 lei.
-bieleta antibalans 90 lei de origine
-bielete antiruliu 70 lei setul.
-suport cv 110 lei buc
-bascule 120 lei .de origine.
-ploape far 25 lei setul.
-oglinzi prestige 340 lei noi pe culoare la comanda.
-camera video .100 lei.
-becuri leduri pentru pozitii,semnalizare,plafoniera,suport numar 15 lei.
- incalzitor bujii dci 70 lei.
-cheie cu baterie si cip 40 lei.
-reparatie injectoare delphi 180 lei buc.
-supape 1,4.1,6 190 lei setul.
-maciulie piele.55 lei
-prelungire bara sandero .60 lei
-ambreiaj complet. placa, disc, rulment, 390 lei.
-inele aeratoare plastic .rosi,albastre argintii..20lei setul.
-contactot frana.40 lei.
-suporti proiectoare la 30 lei.
-cablaj proiectoare la 40 lei.
-senzor turatie 65 lei.
.-garnitura chiuloasa 60 lei.
-termostat dci 1oo lei.
.-rola accesorii 55 lei
-intanzator pentru ac.150 lei.
-bixenon la 250 lei.....nou
-prelungire bord ph2 40 lei.
-Folie omologata LUMMAR..300 lei.cu montaj cu tot.doar in Pitesti.
-macarale geamuri electrice fata 300 lei setul
-bloc lumini cu proiectoare.plus comanda stergatoare cu ci.160 lei.
-toba finala mare 290 lei.
-toba finala mica 180 lei.
-antena cb ml 145 .600w .120 lei.
-opritor usa 40 lei nou.
-contactori usi.25 lei buc.noi.
-bucsi bara stabilizatoare.40 lei setul.noi.
-distributie 1,4 1,6 150 lei.
-sonda mers inapoi 50 lei.
-filtru ulei benzina 25 lei original.
-bujii NGK 65 lei setul.
-bujii EQM cu 2 electrozi.70 lei setul.
-pompa servo electrica 1.000 lei.originala noua.
-supape logan 1,4.180 lei setul.
-scaune supape 1,4.90 lei.
-semeringuri 1,4. 80 lei.
-flansa amortizor 50 lei.
rulment amortizor 35 lei.
-Resoftari diesel 180 lei
benzina 130 lei.
-Schimbat lumini bord,clima,butoane,plafoniera,activare sprit la stergatoare.mai multe..preturi neg.
relatii la tel; 0764700304 sau id ul de mess . florin_dnfsigpic!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Vand telefon NOKIA E90, unic proprietar, GPS incorporat, fara a utiliza coexiune internet, poate fi utilizat ca si router wireless pe o distanta de 20 metri, camera de 3.2 mp, card memorie, pachet complet, pret 800 ron neg. tel 0768471313, sau PM
Vand 600grame vopsea rosu passion pentru logan, pe baza de diluant, necesita lacuire.
Pret 70lei.
La policolor costa 20lei 100grame iar cutia de 1kg costa 164lei.
Diagonala :17
Tip tub : DynaFlat
Standarde: MPR-II
Display
