[Vand] Consumabile si piese noi
Anunt valabil in continuare.
- maciulie piele prestige------------- 70 ron
- surub golire ulei cu garnitura-------15 ron
- folie cadranealba cu ace rosii------35 ron
- set chedere suplimentare usi-------20 ron
hunior ai poza cu bieleta da van
Anunt valabil in continuare, precizez ca unele preturi se pot modifica ulterior ofertei afisate:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc
- bloc lumini cu proiector model Valeo------------ 170 ron
- bucsi bascule de origine ------------------------ 25 ron/buc
- bujii Equiem cu 2 craci-------------------------- 60 ron/set
- bujii Equiem cu 1 crac---------------------------50 ron/set
- termostat (producator) LG diesel--------------- 115 ron
- cap bara Lemforder ----------------------------- 85 ron/buc
- bieleta directie Lemforder------------------------ 85 ron/buc
- cap bara de origine------------------------------ 85 ron/buc
- bielete directie de origine------------------------ ron/buc
- cap bara SWAG----------------------------------75 ron/buc
- bielete directie SWAG----------------------------60 ron/buc
- termostat benzina------------------------------- 35 ron
- pivoti (LEMFORDER)------------------------------ 40 ron
- bascula de origine------------------------------- 110 ron
- set saboti (FERODO)----------------------------- 125 ron
- nuca schimbator Prestige plastic------- ---------- 40 ron
- nuca schimbator Prestige piele--------------------70 ron
- bucsi bara stabilizatore mijloc -------------------- 35 ron/set
- bielete antiruliu de origine ------------------------ 55 ron/set
- set rulmenti roata fata FAG (fara ABS)-------------175 ron/set (2 buc)
- filtru ulei original MPI ---------- ------------------- 20 ron
- filtru ulei original DCI ----------------------------- 20 ron
- filtru ulei MANN-FILTER---------------------------- 20 ron
- filtru ulei DUSTER-----------------------------------30 ron
- filtru aer benzina si motorina ----------------------- 25 ron
- filtru aer MANN-FILTER (mpi) ----------------------- 33 ron
- filtru aer MANN-FILTER (dci)-------------------------43 ron
- filtru aer 16 valve --------------------------------- 30 ron
- filtru motorina EURO 3 ---------------------------- 110 ron
- filtru motorina EURO 4 ---------------------------- 110 ron
- filtru polen Valeo ---------------------------------- 25 ron
- oglinzi Prestige electrice ---------------------------250 ron/set
- proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
- buton reglaj oglinzi electrice ------------------------35 ron
- buton deschidere usa -------------------------------10 ron
- amortizoare Monroe fata ----------------------------120 ro/buc
- amortizoare Monroe spate --------------------------105 ron/buc
- amortizoare Bilstein B4 fata -------------------------145 ron/buc
- amortizoare Bilstein B4 spate ------------------------125 ron/buc
- flanse amortizor originale -----------------------------40 ron/buc
- rulmenti amortizor SNR -------------------------------25 ron/buc
- bieleta antirasturnare --------------------------------70 ron
- bieleta antirasturnare VAN----------------------------80 ron
- discuri frana VAN Brembo --------------------------- 135 ron/buc
- placute frana VAN Ferodo SL ------------------------125 ron/set
- placute frana VAN BOSCH ---------------------------150 ron/set
- placute frana VAN TRW ----------------------------- 170 ron/set
- discuri frana 259 pline Ferodo ------------------------190 ron/set
- discuri frana 259 ventilate Ferodo --------------------210 ron/set
- discuri frana 259 pline Brembo------------------------190 ron/set
- discuri frana 259 ventilate Brembo---------------------240 ron/set
- discuri fraba 259 ventilate Brembo Striate-------------400 ron/set
- discuri frana ventilate RoadHouse---------------------140 ron/set
- discuri frana ventilate Origine ------------------------260 ron/set
- placute frana TRW ----------------------------------- 60 ron/set
- placute frana Ferodo FQT ----------------------------125 ron/set
- placute frana Ferodo Premier--------------------------95 ron/set
- placute frana ORIGINE(FRANTA)------------------------90 ron/set
- placute frana VAN (BOSCH)----------------------------140 ron/set
- cablu ambreiaj MPI-DCI -------------------------------50 ron
- cablu acceleratie MPI -------------------------------- 35 ron
- sonda servodirectie -----------------------------------50 ron
- sonda mers inapoi -------------------------------------35 ron
- plafoniera 3 becuri ------------------------------------35 ron
- plafoniera 1 bec ---------------------------------------30 ron
- contactor lumina pedala frana ------------------------- 40 ron
- spirala airbag volan ------------------------------------ 70 ron
- kit distributie MPI -------------------------------------140 ron
- pompa apa de origine MPI -----------------------------170 ron
- kit distributie DCI ------------------------------------- 230 ron
- pompa apa DCI ----------------------------------------180 ron
- kit ambreiaj SACHS 1.6 MPI ---------------------------- 380 ron/set
- kit ambreiaj Origine 1.4 MPI-----------------------------340 ron/set
- kit ambreiaj DCI producator LUK-------------------------410 ron
- rulment ambreiaj hidraulic Valeo-------------------------180 ron
- curele accesorii ---------------------------------------- 55 ron
- kit accesorii MPI model cu AC de origine -----------------240 ron
- kit accesorii DCI model cu AC de origine -----------------255 ron
- role ghidaj MPI/DCI------------------------------------- 35 ron
- actuator usi origine------------------------------------ 35 ron/buc
- spray luciu anvelope ------------------------------------25 ron
- autocolante stalpi Prestige ------------------------------35 ron/set
- aeratoare Prestige argintii -------------------------------65 ron/set
- aeratoare Duster cromate--------------------------------60 ron/set
- duze stropitor tip perdea---------------------------------15 ron/set
- carenaje roti origine--------------------------------------65 rom/buc
- chedere scurte usi Logan ---------------------------------20 ron/ set de 4 buc.
- ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
- ARAL HIGH TRONIC 5W-40 1L------------------30 ron
- CAS EDGE 5W-40/1 T.D. 5W40 -1L------------38 ron
- CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
- CAS EDGE 5W-40/5 T.D. 5W40 -5L------------155 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------42 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------175 ron
- CAS EDGE 5W-30 5W-30 -1L ----------------47 ron
- CAS EDGE 5W-30 5W-30 -4L ----------------170 ron
- CAS EDGE 5W-30 5W-30 -5L ----------------195 ron
- CAS MAGNATEC C3 5W-40 -1L ----------------38 ron
- CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
- CAS MAGNATEC C3 5W-40 -5L ----------------145 ron
- CAS MAGNATEC DIESEL B4 5W-40 -1L-------------40 ron
- CAS MAGNATEC DIESEL B4 5W-40 -4L------------136 ron
- CAS MAGNATEC BENZINA 10W-40 -1L-------------32 ron
- CAS MAGNATEC BENZINA 10W-40 -4L-------------110 ron
- CAS MAGNATEC BENZINA 10W-40 -5L--------------135 ron
- CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron
- CAS MAGNATEC DIESEL 10W-40 -4L---------------110 ron
- CAS MAGNATEC DIESEL 10W-40 -5L---------------135 ron
- ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron
- ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron
- ELF COMPETITION ST 10W-40/4L------------------70 ron
- ELF COMPETITION ST 10W-40/1L------------------25 ron
- ELF TURBO DIESEL 10W-40/5L---------------------110 ron
- ELF TURBO DIESEL 10W-40/4L---------------------80 ron
- ELF TURBO DIESEL 10W-40/1L---------------------25 ron
- MOBIL SUPER 3000 5W-40/4L----------------------125 ron
- MOBIL SUPER 3000 5W-40/1L-----------------------35 ron
- VAT OIL SYN TECH 10W-40/1L --------------------- 20 ron
- VAT OIL SYN TECH 10W-40/4L --------------------- 70 ron
- VAT OIL SYN GOLD 5W-40/1L----------------------- 30 ron
- VAT OIL SYN GOLD 5W-40/4L----------------------- 100 ron
- VAT OIL SYN TECH DIESEL 5W-40/1L---------------- 30 ron
- VAT OIL SYN TECH DIESEL 5W-40/4L --------------- 100 ron
- VAT OIL SYN TECH LL-X 5w-40/1L (specificatie renault)-----30 ron
- VAT OIL SYN TECH LL-X 5w-40/4L (specificatie renault)---- 95 RON
si multe altele...se pot aduce si piese pentru masini straine,
mentionez ca piesele sunt de origine.
evali_daniel este id-ul meu pe mess.
0766.403.938 VALI
da, setul de chedere cuprinde 2 chedere mici si 2 chedere mai lungi de Duster.
Salut,setul de chedere cuprinde 2 mari si 2 mici?ca nu se vede prea clar in poza.
Multumesc.
Daniele un set de bascule st+dr echipate de origine gasim ? Ca am vrut sa fac azi geometria si am joc in ambele bascule, la pivoti. Respect si ne auzim !!!
STR8 =»»HTC =»» Forum Runner
Produs nou:
- lamele stergator origine Logan ------------ 20 ron/buc
salut rola de la intinzator si cea de ghidaj sunt la fel? ce firma sunt?
@VALLIO, nu am prezoane.
@L3on_rgby nu am carcasa de aer pt 1.2
