[Vand] Consumabile si piese noi
@emilemy ai PM
Anunt valabil in continuare, precizez ca unele preturi se pot modifica ulterior ofertei afisate:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc
- bloc lumini cu proiector model Valeo------------
- bucsi bascule de origine ------------------------ 25 ron/buc
- bujii Equiem cu 2 craci-------------------------- 60 ron/set
- bujii Equiem cu 1 crac---------------------------50 ron/set
- termostat (producator) LG diesel--------------- 115 ron
- cap bara Lemforder (cu arc)--------------------- 85 ron/buc
- bieleta directie Lemforder------------------------ 85 ron/buc
- cap bara de origine(cu arc)----------------------
- bielete directie de origine------------------------
- cap bara SWAG----------------------------------75 ron/buc
- bielete directie SWAG----------------------------60 ron/buc
- termostat benzina------------------------------- 35 ron
- pivoti (LEMFORDER)------------------------------ 40 ron
- bascula de origine------------------------------- 145 ron
- set saboti (ATE)-------------------------------- 120 ron
- nuca schimbator Prestige plastic------- ---------- 40 ron
- nuca schimbator Prestige piele--------------------65 ron
- bucsi bara stabilizatore mijloc -------------------- 35 ron/set
- bielete antiruliu de origine ------------------------ 25 ron/buc
- rulment roata fata FAG (fara ABS) ----------------105 ron/buc
- set rulmenti roata fata FAG (fara ABS)-------------175 ron/set (2 buc)
- burduf planetara CV stanga Logan------------------80 ron
- filtru ulei original Purflux benzina ------------------- 20 ron
- filtru ulei original Motorina ------------------------- 20 ron
- filtru ulei MANN-FILTER----------------------------- 20 ron
- filtru ulei DUSTER-----------------------------------30 ron
- filtru aer benzina si motorina ----------------------- 25 ron
- filtru aer MANN-FILTER (mpi) ----------------------- 33 ron
- filtru aer MANN-FILTER (dci)-------------------------43 ron
- filtru aer 16 valve --------------------------------- 25 ron
- filtru motorina EURO 3 ---------------------------- 100 ron
- filtru motorina EURO 4 ---------------------------- 100 ron
- filtru polen Valeo ---------------------------------- 25 ron
- oglinzi Prestige electrice ---------------------------250 ron/set
- proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
- buton reglaj oglinzi electrice ------------------------35 ron
- buton deschidere usa -------------------------------10 ron
- amortizoare Monroe fata ----------------------------115 ro/buc
- amortizoare Monroe spate -------------------------- 105 ron/buc
- amortizoare Bilstein B4 fata ------------------------- 145 ron/buc
- amortizoare Bilstein B4 spate ------------------------125 ron/buc
- flanse amortizor originale -----------------------------40 ron/buc
- rulmenti amortizor SNR -------------------------------25 ron/buc
- bieleta antirasturnare --------------------------------70 ron
- bieleta antirasturnare VAN----------------------------80 ron
- discuri frana VAN Brembo --------------------------- 135 ron/buc
- placute frana VAN Ferodo SL ------------------------125 ron/set
- placute frana VAN BOSCH ---------------------------150 ron/set
- placute frana VAN TRW -----------------------------170 ron/set
- discuri frana 259 pline Ferodo ------------------------190 ron/set
- discuri frana 259 ventilate Ferodo --------------------200 ron/set
- discuri frana 259 pline Brembo------------------------190 ron/set
- discuri frana 259 ventilate Brembo---------------------240 ron/set
- discuri fraba 259 ventilate Brembo Striate-------------390 ron/set
- discuri frana ventilate RoadHouse---------------------140 ron/set
- discuri frana ventilate Origine ------------------------260 ron/set
- placute frana TRW ----------------------------------- 60 ron/set
- placute frana Ferodo FQT ----------------------------125 ron/set
- placute frana Ferodo Premier--------------------------95 ron/set
- placute frana ORIGINE(FRANTA)------------------------100 ron/set
- cablu ambreiaj MPI-DCI -------------------------------50 ron
- cablu acceleratie MPI -------------------------------- 35 ron
- sonda servodirectie -----------------------------------50 ron
- sonda mers inapoi -------------------------------------35 ron
- plafoniera 3 becuri ------------------------------------35 ron
- plafoniera 1 bec ---------------------------------------30 ron
- spirala airbag volan ------------------------------------ 70 ron
- kit distributie MPI -------------------------------------150 ron
- pompa apa de origine MPI -----------------------------200 ron
- pompa apa HEPU pt benzina ---------------------------175 ron
- kit distributie DCI ------------------------------------- 260 ron
- pompa apa DCI ----------------------------------------210 ron
- kit ambreiaj SACHS 1.6 MPI ---------------------------- 380 ron/set
- kit ambreiaj Origine 1.4 MPI-----------------------------340 ron/set
- kit ambreiaj DCI producator LUK-------------------------350 ron
- rulment ambreiaj hidraulic Valeo-------------------------170 ron
- curele accesorii ---------------------------------------- 55 ron
- kit accesorii MPI model cu AC de origine -----------------240 ron
- kit accesorii DCI model cu AC de origine -----------------255 ron
- role ghidaj MPI/DCI------------------------------------- 35 ron
- spray luciu anvelope ------------------------------------25 ron
- autocolante stalpi Prestige ------------------------------35 ron/set
- aeratoare Prestige argintii -------------------------------65 ron/set
- aeratoare Duster cromate--------------------------------60 ron/set
- duze stropitor tip perdea---------------------------------15 ron/set
- set chedere scurte Logan nou----------------------------20 ron/set
- obturatoare praf ----------------------------------------20 ron/set
- ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
- ARAL HIGH TRONIC 5W-40 1L------------------30 ron
- CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron
- CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
- CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron
- CAS EDGE 5W-30 5W-30 -1L ----------------51 ron
- CAS EDGE 5W-30 5W-30 -4L ----------------190 ron
- CAS EDGE 5W-30 5W-30 -5L ----------------215 ron
- CAS MAGNATEC C3 5W-40 -1L ----------------35 ron
- CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
- CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron
- CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron
- CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron
- CAS MAGNATEC BENZINA 10W-40 -1L-------------30 ron
- CAS MAGNATEC BENZINA 10W-40 -4L-------------115 ron
- CAS MAGNATEC BENZINA 10W-40 -5L--------------130 ron
- CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron
- CAS MAGNATEC DIESEL 10W-40 -4L---------------115 ron
- CAS MAGNATEC DIESEL 10W-40 -5L---------------130 ron
- ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron
- ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron
- ELF COMPETITION ST 10W-40/4L------------------85 ron
- ELF COMPETITION ST 10W-40/1L------------------25 ron
- ELF TURBO DIESEL 10W-40/5L---------------------110 ron
- ELF TURBO DIESEL 10W-40/4L---------------------85 ron
- ELF TURBO DIESEL 10W-40/1L---------------------25 ron
- MOBIL SUPER 3000 5W-40/4L----------------------125 ron
- MOBIL SUPER 3000 5W-40/1L-----------------------35 ron
si multe altele...se pot aduce si piese pentru masini straine,
mentionez ca piesele sunt de origine.
evali_daniel este id-ul meuAttached Files- 687272996210004196358229-1074232-700_700.jpg (48.1 KB, 462 views)
Salutare ! Pt un Logan 1.4 , PH1 din 2006 , imi faci si mie un pret la urmatoarele ? -1 termostat de origine -1 set placute frana de origine -1 set bujii de origine -1 filtru polen de origine Multumesc frumos , o zi frumoasa !!!!
Multumesc pentru piese domnu' Vali , 10+
maciulie schimbator ai Daniel? dacă da dă-mi un pm cu prețul
Sent from my GT-I9300 using Forum Runner
Azi am primit piesele, urmeaza montarea lor cand o sa-mi permita vremea. Recomand cu incredere
Nu am rulmenti de alternator, cu pivoti lemforder sunt echipate basculele.Last edited by 77sky; 13 October 2014, 22:56.
Salut, rulmenti alternator ai ?!!
Basculele sunt echipate cu pivoti trw sau lemforder ?!
Am primit astazi o cutier de 19kg cu..cu..cu..piese de calitate
Multumesc Daniel pt promptitudine.
