  • No help possible with your zero information. Which vehicle, which type of control unit, which firmware?
    • Here, Dacia Logan 1.4 2008
      • Thank you very much, I tried to make it work a whole year. Do you know by any chance if I can make it work (maybe change the hex)?
        • If the ecu is original and not defective, you have full access with the linked software. If you have already experimented with firmware and the firmware upload is incomplete, there is a chance to fix this problem. Since you do not give a detailed description of the problem with photos, no problem solution is possible.
          • The linked software works and there's no other problem, I just wanted to use Plus Max because it's easier to use.
            • Salut, cine ma ajuta sa configurez si eu Landi Renzo Omegas, cu aplicatia asta. Sunt incepator si am nevoie de putina indrumare, va rog mult
              • Buna seara daca are cineva sistemul de gpl cu ecu de gaz landi renzo omegas cod 616000294 cu injectoare girs12 cu ce soft operati?
                • LR OMEGAS v.4.2.2.20
                  • Buna ziua!
                    astazi dupa 8 ani De Tomasseto stag4 Qbox nu mai vrea sa porneasca . Cand pun contactul bipaie De 3 ori cate 3 si se opreste. Ce poate fi???? Multumesc!!
                    • Am pus interfata cand am ajuns acasa si am gasit aceasta setare ca in imagine ... am debifat
                      • Originally posted by logandriver3 View Post
                        Salut! Cred ca sunt in situatia asta. Am incercat sa scriu un firmware cu plusmax2010 pe un ecu origilal logan, lc02 si nu s-a incarcat complet. Acum e cumva inactiv, nu se mai aprinde niciun led. Ai vreo idee ?
                        • Without details, no ideas are available.
                          • Ok, dar de ce detalii ai nevoie?
                            • Ecu este un landi 616569000
