No help possible with your zero information. Which vehicle, which type of control unit, which firmware?
Here, Dacia Logan 1.4 2008
If the ecu is original and not defective, you have full access with the linked software. If you have already experimented with firmware and the firmware upload is incomplete, there is a chance to fix this problem. Since you do not give a detailed description of the problem with photos, no problem solution is possible.
- Likes 1
Am pus interfata cand am ajuns acasa si am gasit aceasta setare ca in imagine ... am debifatAttached Files
Salut! Cred ca sunt in situatia asta. Am incercat sa scriu un firmware cu plusmax2010 pe un ecu origilal logan, lc02 si nu s-a incarcat complet. Acum e cumva inactiv, nu se mai aprinde niciun led. Ai vreo idee ?Originally posted by logandriver3 View PostIf the ecu is original and not defective, you have full access with the linked software. If you have already experimented with firmware and the firmware upload is incomplete, there is a chance to fix this problem. Since you do not give a detailed description of the problem with photos, no problem solution is possible.
