  • Originally posted by cristi.... View Post
    eu zic ca au scos martoru de temp lichid racire pt ca la logan 1 invariabil, la un moment dat, aveai jocu ala de pavele 4-2-4 pe care nu-l puteai rezolva nicicum: nici cu sonde schimbate nici cu termostate. asa ca decat sa-si faca utilizatoru probleme inutile l-au scos si cu asta basta, nu mai esti stresat
    legat de parametrii pe care ii ia in calcul ”senzoru” de calitate ulei, acestia ar fi nr de porniri/ temp motorului, turatii, viteza rulare, sarcina pe motor etc. daca vreti sa nu va uzati uleiu prematur dezactivati prostia aia de start-stop
    nu e nici un secret, info astea sunt deja fumate demult
    ”Algorithm-based oil indicators measure lots of factors and then plug the resulting numbers into a formula. Based on the answer to this complex, ongoing math problem, the indicator display will tell you whether the oil is OK, is close to requiring replacement or needs replacing immediately.
    Interestingly, with these types of indicators, there are no sensors to detect the quality of the oil itself. Instead they combine data on how many miles you've driven, the temperature variations during that time and data about how much work the engine has performed. Typically, the indicator (monitoring system) will receive such data from the powertrain control module, or PCM, which is the main on-board computer. Engineers have figured out a fairly accurate and reliable way to calculate the remaining oil life this way, without having to actually sample the oil.
    nu e masurare directa, e o estimare bazata pe un algoritm
    on topic
    mi se pare mie sau loganu asta 2 are mai multe probleme decat generatie precedenta?
    mai merita asumat riscu cu noul model? intrebare adresata posesorilor de logan 2, in special celor cu motor de 1.2/0.9
    de 0.9 n-am citit multe lucruri de rau, de 1.2 insa da
    ca posesor de logan 1 sunt f multumit de fiabilitatea acestui model, insa citind threadu asta imi dau seama ca logan 2 e sub logan 1 la aspectu asta, de altfel cel mai imp la o masina din pct meu de vedere
    Ti se pare tie.
    • Iata ce zice un document oficial Renault:
      OCS (Oil Control System) for lower running costs
      Following its introduction on the dCi range, the Oil Control System (OCS) is now available for the
      TCe 100 and TCe 130 engines, too. This feature uses the engine's ECU to calculate servicing
      intervals as a function of the way the vehicle is used. Should running conditions be considered
      too severe (e.g. door-to-door type city motoring exclusively), a warning on the dashboard invites
      the driver to bring forward the next oil change. OCS enables Renault to recommend competitive
      oil change intervals, while at the same time providing a solution that protects those owners who
      stray from conventional use. OCS employs an algorhythm which notably takes into account the
      vehicle's road speed and engine speed. OCS is today fitted to the TCe 100 and is poised to be
      extended to all the Renault range's TCe and dCi powerplants.
      Deci, e din soft. Case closed.
      • t0rquemada pai citeam non-stop temperatura motorul (nu indicatorul din bord). Si asa mi-am dat seama unde era hiba...Cel putin la mine era termostatul. Dar nu m-am deranjat sa-l schimb a doua oara. Nu scade sub 80 grade...iar temperatura superioara era tot timpul in limitele normale. Afara 84-86 grade, in oras...doh...99-102 grade (la 102 pornea GMV-ul)
        @MihaiiahiM asa...
        • ,Sonda de temperatură de pe motor(aia de citește temperatura pentru injecție și TdB) are nevoie de masă și cum masa pe motor e deficitară citești deja eronat.
          • t0rquemada ts...nop. Verificat Initial si eu am crezut asta. De regula cand este o masa deficitara, pot aparea variatii in functie de conditiile meteo. De exemplu, daca-i umiditate mare...poate sa arate bine...daca-i uscat...poate arata eronat.
            Mai pateam asta cu senzorul de noxe...cand era foarte umed afara...noaptea se vedea cum palpaie ledul...probabil intra umezeala undeva.
              *intervalul de revizie de pe TdB care lipseste la 1,2 16v și 1,6 16v(H4M Logan II)
              H4M pe Logan 2? Unde? Cand? Cum?
              Eu stiam ceva de K4M pe Rusia.
              • Rusia, Brazilia,...dar exista.
                • Pe Rusia stiam de K4M cum am mai zis, iar in Brazilia s-a renuntat la K4M este doar K7M(1.6 8v), dar ei au F4R(2.0 16v).
                  • Da, mai nou există B4D(kwid 999cm3 3cil) și H4M e Logan II și Sandero II, sunt 3 modele.
                    Ontopic: ots pt planetare(se schimbă) puse pe loturi mici de X52(inclusv fabricate în RO), X67, X92 și X90(da, asta încă se fabrică) - alte detalii nu pot da, informația se găsește la liber trebuie doar căutată.
                    • Probleme Tehnice Logan II
                      Da, mai nou exist B4D(kwid 999cm3 3cil) i H4M e Logan II i Sandero II, sunt 3 modele.
                      Ontopic: ots pt planetare(se schimb) puse pe loturi mici de X52(inclusv fabricate în RO), X67, X92 i X90(da, asta înc se fabric) - alte detalii nu pot da, informaia se gsete la liber trebuie doar cutat.
                      Am cautat pe internet si nu am gasit
                      Am gasit ceva legat de bielete axiale.....sau alea sunt )
                        ... eu suspectez o masa insuficienta pe undeva
                        Poti sa pui o masa suplimentara. De la baterie la caroserie si de la baterie la motor.
                        • Eventual pe suportul (de ridicat motorul) de tablă vopsit și corodat care oricum nu are contact ferm cu blocul motor.
                          Problemele X90-ului au topic dedicat.
                            X90 e o Lada si un Nissan in rusia si Tondar in Iran.
                            • Păi nu prea, seria de fabricație la X90 e cu Fxxxxxx
                              • Asa, si care e legatura ca nu ma prind?
